CC im Corsa D
    Original von JoHo
    Ob es mit einem TID auch Funktioniert, bezweifel ich.
    wenn jemand mit nem TID Zeit und lust hat, kann er es ja mal ausprobieren. Könnte es wenn, dann erst nächste Woche mal irgendwann testen.
    Hi, Jonas
    My Corsa's display is a TID.
    After I read your post, I wondered if it's possible and went to my private Opel garage. We connected the Tech2 and followed the steps you wrote in your previous post.
    The first four steps were OK, but when we selected the "Progr. Varianten Konfiguration" option, a screen with only two options displayed.
    First option was the country code, and the second option was EHU (Entertainment Headphone Unit, I guess).
    You wrote "Punkt 9". Does that mean there should be 9 or more options on that screen ?
    Anyway, there wasn't anything like "Check Control" in the screen.
    I guess my car doesn't have the Check Control system or it doesn't work with TID. Am I correct ?
    Corsa 1.4 Sport, 5-türig, Magmarot, Schaltgetriebe
    Panoramaschiebedach, ESP, 17" stern-design felgen, ContiSportContact3 215/45 reifen
    Nachrüstung : Tempomat, Bordcomputer, Sitzheizung, HSA, DDS, Solar Reflect windschutzscheibe, Solar Protect getönt glas im rückseite, dunkel getönt rückleuchten, OPC-Line bodykit, OPC-Line interieur-paket, AFL, Touch & Connect
    2 Mal editiert, zuletzt von saytamaner ()
    Original von saytamaner
    Yes! TID is not able to display the information of the CC. ;)
  • Too bad! ;(
    Then I should ask another question :
    Is there anybody who replaced the TID with GID or CID ?
    Is that possible ?
    A quick "yes" or "no" answer would be enough for me, then I will use the search function and try to read & understand the relevant threads in the forum, I promise :]
    mfg,
    Serdar
  • I'm not really sure, if someone has replaced a TID with GID or CID.
    But, snowboardman replaced the GID with CID -> Link
    Maybe, it will helps you
  • impossible is nothing. but It's not so easy!
    The Cable rate of the Harness for the TID has fewer lines than the Harness for GID / CID.
    I can give you a
    Tomorrow, when I have a look at the schematic, I can give you a more precise answer.
    kind regards, Jonas
  • That would be very kind of you, Jonas!..
    Thank you very much :)
  • Hallo Jonas
    Danke für die Anleitung.
    Gruß Georg
    Corsa D Sport 1,4 TP 3T 5G - Farbe: Metro - OPC-Line-Paket 1 - Parkpilot - Adapt. Fahrlicht AFL - LM Räder 7x17 5 Speichen Stern - Winterpaket - Vorteilspaket - 3.Kopfstütze hinten
    Veränderungen: dunkle Rückleuchten vom OPC, Philips NightGuide H7/S für Abblendlicht, Philips NightGuide H1 für Fernlicht, CC aktiviert
  • @ Joho ,
    so dank Deiner Anleitung hat es mein FOH jetzt auch hin gekriegt , hat nur ein wenig gedauert weil paar mal Probiert hat weil meinte es müsste beim Starten die Anzeige kommen das Bremse drücken soll.
    Erster Kommentar war dann " Geht nicht , wäre alles unnütze Arbeit und das meiste stimmt eh nicht im Internet " , dann ist Junior Chef dazu gekommen hat einmal ins Tech 2 geschaut 2Tasten gedrückt und ist an Kofferraum gegangen und hat Kabel abgezogen von Rückleuchte und sie da die Anzeige ging an 8o
    :lol: Meinte dann nur " Gut das der Chef wenigstens bei der Fortbildung aufgepasst hat " , der Mech. saß erst mal ganz verdattert im Auto und meinte " ja und der Bremstest ??? " , darauf der JR Chef " den gibt es nicht weil kein Voll CC und Er soll das Auto raus fahren damit weiter geht " , hab dann noch ne Tasse Kaffee bekommen und den neusten Zubehörkatalog für 0 € :tongue:
    Opel Corsa D 1.3CDTI DPF 90PS Sport , Starsilber , Vorteilspaket & Quickheat
  • Ich habe das auch in Auftrag gegeben. Bin ja gespannt der Junior Chef macht da einen guten Eindruck.
    Er muss das also einspielen und zu aktivieren muss man einen Fehler produzieren?
    Einmal editiert, zuletzt von Opel-Treiber ()
