Hello
Sorry for english
I did hsa and dds retrofit nomally i never found hsa and dds supported a car upwards 2011 as you know opel changed the abs socket after 2009 and i couldn t find abs ecu which supported hsa and dds on z13dtj. i bought a old socket abs ecu. A friend help me about VIN for sps programming so only thing how to do converter between old abs ecu socket and new abs ecu socket i made it within 1 day..so it worked very well no DTC.. but i got new problem central auto lock was not working regular but it s strange auto central lock is working sometimes or not as you know it s activating after 10 km/h...even stop engine and restart it s not working.. I have also touch and connect so it was working on ignition 1 but it s not working on ignition 1 anymore it works in ignition 2 after stop the engine t&c is also turning off[Blockierte Grafik: http://www.ukcorsa-d.com/forum/images/smilies/icon_sad.png](
what i have done maybe you can give me an idea about issue...
1) esp retrofitted with new socket(everthing was ok)
2) after replace old ecu with my converter tool , i didn t realize but it was working central lock and ignition 1 radio problem.. maybe i remember wrong
3) i changed the hazard switch because of dds button maybe i thought problems is hazard switch and i changed it with old one but no luck it s same problem it was not working..
4) i thought maybe problem is BCM i replaced the old one but ignition problem continues i couldn t check auto door lock system because i had to program it again..
5) I replaced with new socket old abs module nothing change, radio ignition problems continues:((
i don t have any DTC it s clear but i have these problems What do you think about that ??
[Blockierte Grafik: http://uploads.tapatalk-cdn.com/20180216/ea2696f012971e81971a7abc02917e7b.jpg]
[Blockierte Grafik: http://uploads.tapatalk-cdn.com/20180216/fcaecb638ba64924d5e7e7a7ab016d34.jpg]
[Blockierte Grafik: http://uploads.tapatalk-cdn.com/20180216/33d65096c700875ce0e8755a11b34d6a.jpg]
[Blockierte Grafik: http://uploads.tapatalk-cdn.com/20180216/415c379434bb268e9ba0947f971fbe8c.jpg]
[Blockierte Grafik: http://uploads.tapatalk-cdn.com/20180216/9cddb7f859cfa3212024fa98d778d0d2.jpg]
[Blockierte Grafik: http://uploads.tapatalk-cdn.com/20180216/8a95a5db6d8cbcb6c530a64309a1f8c1.jpg]
[Blockierte Grafik: http://uploads.tapatalk-cdn.com/20180216/a614ef9dee031bb7e77ac65317a08f26.jpg]
