spacers help
  • hello from the only corsa opc owner in malta!
    i am talking to ssc to buy 10mm front/13mm rear spacers and have some questions pls.
    which spacers fit perfectly on rear hub without use taking off grease cover?
    what spacers are you running on standard 18s without rubbing?
    if i run 10mm front and 15mm rear, would i unbalance the car's behaviour and induce oversteer?
    i am lowered on eibach pros.
    thank you.
